will2
Mar 5, 2010 4:29 PM UTC
Sample firmware not working?
Posted on March 05, 2010 at 17:29
    lowpowermcu
    May 17, 2011 1:07 PM UTC
    Posted on May 17, 2011 at 15:07
    I have found the following notes regarding the beep example, did you checked it ?
       - Verify that the JP14 is on the up position (to enable the speaker on the STM8/128-EVAL)
       - Verify the speaker volume by adjusting the RV2 potentiometer position on the STM8/128-EVAL
    Regards,
    lowpowermcu
    will2
    will2Author
    I've been messing around with this a bit more...I think the problem was that the interrupt was not firing.  I changed to the sample project where the GPIO is polled instead of interrupt driven, and it worked.
    Thanks for your input!
