rganti
May 9, 2008 6:12 PM UTC
Running Bootloader from Bank1 and Switch to Bank0 Application
Posted on May 09, 2008 at 20:12
rganti
rgantiAuthor
May 17, 2011 7:53 AM UTC
Posted on May 17, 2011 at 09:53
I did develop a bootloader for ARM9 to run from Bank1 and later switch to bank0. When I ran the same bootloader from Bank0 I could debug and test its working.
But when I changed the program to run from Bank1 (in IAR 5.10 Release Mode) its not working. Using JlinkSTR91x.exe I am changing boot bank to 1 by running the command the ''setb 1''. Then trying to load the program to flash from IAR (Release Mode). Then I tried to cycle power the ST ARM9 MCU but my program doesn't seem working.
Any ideas quickly??
sjo
It will only work with revH silicon.
see the errata for more details.
Cheers
sjo
