ekpol
Aug 1, 2014 10:09 AM UTC
run menu disabled in ST Visual Develop
Posted on August 01, 2014 at 12:09
I'm using STVD+cosmic compiler and STM8s-discovery board, i test a little bit and go away for a long time.
After i change the new computer and install STVD, cosmic,
plug the USB cable to board , the board running fine.
I open project ''PWM'' from example,
 compile with out error, can debug but the 'run' menu is diabled, what's wrong ?
    ekpol
    ekpolAuthor
    Aug 4, 2014 10:22 AM UTC
    Posted on August 04, 2014 at 12:22
    It can do now, first, Start to debug, and follow by run command.
