taylor
Mar 11, 2010 7:10 PM UTC
RTC Lockup?
Posted on March 11, 2010 at 20:10
RTC Lockup?
taylor
taylorAuthor
May 17, 2011 8:00 AM UTC
Posted on May 17, 2011 at 10:00
Follow-up observation:
I have tried physically shorting the 32K RTC crystal to generate an artificial RTC failure (I needed to test new code that was added to deal with the earlier loss of RTC).  The results are perplexing.  My RTC fails ... permanently.  I suspect I am overdriving the drive circuit on the STR9 chip (probably the inverter).  Not quite the result I expected.
