p__it
Mar 4, 2009 4:21 AM UTC
RTC Buffer with Battery
Posted on March 04, 2009 at 05:21
p__it
p__itAuthor
i want to Buffer the RTC of my STR752 with a Battery. So when i take of the voltage from the whole device only the RTC (Date/Time) should go on.
And when i put back the voltage the device should start up with the correct time and date. So i dont have to set the time and date manually after i shut down the device.
I read in the Reference Manual about the Standby mode. But there you have to put your Controller by software command in Standby mode.
Does anyone know how i can handle this?
Kaouther BELHADJ
May 17, 2010 8:12 PM UTC
Posted on May 17, 2010 at 22:12
You can refer to AN2100 :  STR71x Microcontroller Power Management providing different examples on how to configure STR71x low power mode. It may help.
