fechner
Jun 15, 2007 4:09 AM UTC
RLink incompatible to PSDSoftExpress
Posted on June 15, 2007 at 06:09
fechner
fechnerAuthor
May 17, 2011 9:51 AM UTC
Posted on May 17, 2011 at 11:51
if I start WinFLink I get the message:
Error communication (0304)
Hint: This version of the software only handles RLink with
firmware version up to 0.0.255 .
This does not always happen, but always after I programmed the
flash of the PSD813F1-U the first time.
Any idea?
Can I use a newer version of PSDSoftExpress or downgrade the firmware
of RLINK?
I am using PSDSoftExpress 8.66.
Regards:
Uwe Fechner
fechner
fechnerAuthor
some more info:
I can program the PSD successfully once. If I remove the RLINK
from the USB port and connect it to a differt USB port, I can
program the PSD a second time. If I switch back to the first
USB port, it work a third time.
So this is a working workaround, but what is the reason for this
behavior and how to fix it?
Regards:
Uwe Fechner
