jpeacock2
Aug 1, 2007 5:40 AM UTC
REVA w/STR750 daughterboard manual
Posted on August 01, 2007 at 07:40
jpeacock2
jpeacock2Author
Jul 23, 2007 7:01 PM UTC
Posted on July 23, 2007 at 21:01
I recently received a REVA board and STR750 kit (STR750-SK/RAIS). The board quickstart example works fine, but I been unable to locate the manual for the STR750 daughter board anywhere on the web or from the unpacked docs from the included CD. Also, the only example program was a simple echo of switches to LEDs, so I have no idea how the ports map from the STR750 to the REVA main board.
Does this manual exist, and where can I download it?
Jack Peacock
mehdi239955
Jul 30, 2007 8:18 AM UTC
Posted on July 30, 2007 at 10:18
In the Starter kit a CD is included ,where you can find the setup.exe of RIDE (IDE with GNU compiler).
Install RIDE, Go to START->ALL programs->Raisonance kit 6.1->RIDE IDE
then go to help->PDF->STRx tools->Reva daughter board for STRx
You'll find all then necessary.8-)
Regards,
MBS
[ This message was edited by: MBS on 30-07-2007 13:49 ]
jpeacock2
jpeacock2Author
Jul 30, 2007 12:35 PM UTC
Posted on July 30, 2007 at 14:35
No such luck. It shows STR711 and STR730, but no STR750 daughterboard. No STR750 PDF on the Raisonance web site either. Does it exist?
I did check that the RIDE kit was the latest build from the Raisonance website, including P1 and P2 patches.
[ This message was edited by: JakBird on 31-07-2007 02:11 ]
mehdi239955
Quote:
It shows STR711 and STR730, but no STR750 daughter board
I think this should be what you're looking for?8-)
Regards,
MBS
[ This message was edited by: MBS on 01-08-2007 11:11 ]
________________
Attachments :
REva_User_Guide_STR.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtPM&d=%2Fa%2F0X0000000aPZ%2FFL053d40fHEoa20_qwKZNhP.XL2ltkdmJ4Tq.IPuhTw&asPdf=false
