itamar_nsu
Reset Circuit
  • November 24, 2003
  • 787 views
Posted on November 24, 2003 at 09:40
Reset Circuit
itamar_nsu
Posted on November 23, 2003 at 04:24
I'm working with the ST7LITE1. My application is very cost sensitive, battery powered, so i try to reduce the quentity of the external components. Is it ''safe'' to use only internal reset circuit? Should i add an external RC reset circuit? In all of my prev designed i used an external RC, but i'll be happy if i could remove it...
I'll be hapy to hear from your experiance...
Itamar
jatin
November 24, 2003
Yes, you can use the internal reset circuit but you will have to use an external capacitor 0.01 uf between reset and GND. The new revision of the datasheet will have this info.
[ This message was edited by: Jatin on 24-11-2003 14:11 ]
