kbrown
Dec 6, 2002 3:31 AM UTC
Reserved registers
Posted on December 06, 2002 at 04:31
Reserved registers
kbrown
kbrownAuthor
May 17, 2011 9:33 AM UTC
Posted on May 17, 2011 at 11:33
Does anyone know if there is there any side effect of reading a register which is not defined? I'm particularly interested in the 92163.
In order to ensure that I have completely initialized the processor correctly, I want to report the state of all registers once I have completed initialization. It is simpler to just read all registers rather than add code to limit the reads to defined registers. I don't care what undefined registers report, I just want to know if there is any side effect?
Thanks!
romain2399
Several Registers have an ''Intrusive Read'' mode, you can see it when you use the Peripheral Register Window in the debugger. That means that you may reset a flag by reading these registers. You should check each one of them.
I do not think that any hidden register with impredectible impact when read exists.
