txmctaggart
Request advice on parallel port interface probs w/ STVD7 2.5.3
  • August 21, 2003
  • 728 views
Posted on August 21, 2003 at 07:01
txmctaggart
Posted on August 19, 2003 at 21:24
Get the ''Connection error (LPT1): gdi-error in hds: [20016] initialization of the communication with the emulator has failed''
message.
Did uninstall/resintall of application. Read some advice in forums on uninstall of drivers. Could someone clarify just what driver is needed to run the port for the STVD7?
I should mention that am running XP-Professional, and that during the STVD7 install, it complained that the STM par-port driver was missing,a and prompted me to tell it to install it. I don't know what ifanything actually got installed....because it rebooted the PC without telling anything else.
shreya
August 21, 2003
When you try re-installing STVD7, did it try re-installing the parallel port driver?
The details of parallel port driver can be found in the ''Knowledge database'' of this site. Select ST7>Any>Development Tools>STVD7 and see FAQ Ref no. 58375.
