batu
May 22, 2014 11:09 AM UTC
Register Bit Definitions
Posted on May 22, 2014 at 13:09
Dear All,
I've been discovering STM8 core capabilties and properties for a while. I've had a chance to read datasheet for STM8L152. But I couldn't find detailed register info. For instance, CCR (Condition Code) register bit definitions are not clear as far as I saw. Do you have a source (document/web site etc.) to recommend?
Best Regards,
Batu
    chen
    May 22, 2014 1:43 PM UTC
    Posted on May 22, 2014 at 15:43
    Hi
    As is with ST - they spread all the information among many documents!
    The STM8 core is described in the 'Programming Manual'
    http://www.st.com/web/en/resource/technical/document/programming_manual/CD00161709.pdf
    Each processor (eg the STM8L152) will have a data sheet describing  the specifics
    batu
    batuAuthor
    May 23, 2014 8:22 AM UTC
    Posted on May 23, 2014 at 10:22
    Dear Mr. Chung Sung Chen,
    Thank you for your relpy. I didn't know the information that I'm searching was shared in the programming manual (I was expecting it in the datasheet).
    Actually I had downloaded that document but I was supposing the document content was only about instructions and their explanations.
    Again Thank you,
    Best Regards,
    Batu
