pscha.1
référence transistor puissance
Bonjour. Pour éviter de jeter je répare une alimentation Husqvarna .Un transistor de puissance J FET est HS Je ne trouve pas les références sur le marché. Voici les inscriptions y figurant de haut en bas. .Fabricant ST boitier TO220
e3 g
2LNM60ND
G4065 V3
CHNG4 L4L
Un grand merci pour votre aide et votre réponse.
Cordialement
Peter BENSCH
Peter BENSCHBest answer
If the problem is resolved, please mark this topic as answered by selecting Select as best under your preferred answer(s). This will help other users find that answer faster.
Good luck!
/Peter
Peter BENSCH
Welcome, @pscha.1​, to the community!
I've translated your question with a web-based translation tool to increase the chances that you will get an answer from our experts and community members, as the majority communicate in English:
Hello. To avoid throwing away I am repairing a Husqvarna power supply. a power transistor J FET is out of order. Here are the inscriptions appearing there from top to bottom. .Manufacturer ST box TO220
Can you please upload a photo of the component that is as legible as possible?
/Peter
pscha.1
pscha.1Author
June 20, 2022
Peter BENSCH
You could try to replace it e.g. by the STW26N65DM2 or the STW35N65DM2.
Good luck!
/Peter
Peter BENSCH
Good luck!
/Peter
