sr_shinde2
Apr 24, 2010 4:59 AM UTC
Reading Image file using Rflasher
Posted on April 24, 2010 at 06:59
May 17, 2011 8:00 AM UTC
Posted on May 17, 2011 at 10:00
Don't know. Perhaps it is just binary. You could post the file, or examine it with a Hex Editor, or something like XTree/ZTree to view the file. If the file is ASCII, you should be able to recognize if it is an Intel Hex file, or Motorola S-Records. They have lines starting with ':' or 'S' respectively.
Pantuca.Erwin
there is a pdf in the Help menu GettingStartedRFlasher.pdf.
i dont exactly understand what you mean but with rflasher you can read file from your PC to the rflasher memory, read the program image from your device to rflasher memory, or view the data in rflasher memory (either from the file or from device).
