brian4
Dec 15, 2004 7:51 AM UTC
Quick watch and Words
Posted on December 15, 2004 at 08:51
brian4
brian4Author
Dec 2, 2004 11:50 AM UTC
Posted on December 02, 2004 at 12:50
I have defined res_sub as a word i.e.
.res_sub DS.W 1
My code is as follows:-
ld A,{sub_a+1} ; get number A' LSB
sub A,{sub_b+1} ; sub number B' LSB
ld {res_sub+1},A ; store LSB
ld A,sub_a ; get number A' MSB
sbc A,sub_b ; sub number B' MSB with LSB's carry
ld res_sub,A ; store MSB
ret ; and go back to main program
Before I run the code Quickwatch shows res_sub as being a word i.e. res_sub 0xffff
once I have been through this subtract routine Quickwatch shows res_sub as a single byte.
How do I display res_sub as a double byte in my Quickwatch view
Re Brian
emmanuel23
My first question is which version of stvd7 do you use, 3.1.1 or previous ?
Your symptoms look like a problem with debug information.
If you use an old version (2.5.4 and before) or if your project is build around your own makefile, please check the way you build it.
If you use stvd7 3.0.0, please update to the latest version.
If your project was created with stvd7 3.0.0, please open the project settings, activate the ''ST7 Post Link'' tab, then click on OK.
Then rebuild your application.
The problem should have disappeared.
Emmanuel.
