la_it
Apr 10, 2008 8:42 AM UTC
Question on STR910 startup
Posted on April 10, 2008 at 10:42
ibtissem
May 17, 2011 7:51 AM UTC
Posted on May 17, 2011 at 09:51
For IAR it's done by the B ?main, the ''?'' is responsible of copying or remaping the initialized data segment of image into SRAM location.
Same thing is done by __main for ARM compiler/assembler.
For Tasking compiler for example, this is done explecitely in the startup souce file.
Hopefully this clarifies.
Regards,
Ibtissem.
la_it
la_itAuthor
Hi, I have something confused on startup procedure of STR910. I think the program should copy or remap the data segment of image into SRAM location in startup, but I can't find any related part of program in demo. I don't understand how the data segment could be located into SRAM without manual program. Who can explain it to me ?
Thank you
Best wishes
Lalune
jilisegiar
hi,
for IAR and keil it's done automatically when calling B main.
For Raisonance it's done in the startup file before B main.
Rgds
la_it
la_itAuthor
Hi, thank you both for answers. Today I trace startup and found something interesting. In startup, when ''B ?main'' is done, it jumps to a special initializa segment but not main() fuction; Data segments are copied into SRAM here. This special initializa segment is insert by xlink automatical if you set the xcl file with parameter -Q. That means xlink add some assembler codes into your image for SRAM remap when link your obj. That's why I can't found remap codes in startup.
Best wishes
lalune
