dyanova
Dec 19, 2004 8:47 AM UTC
Question about A/D Conversion
Posted on December 19, 2004 at 09:47
daxenberger
May 17, 2011 10:03 AM UTC
Posted on May 17, 2011 at 12:03
you should not exceed VREF of the ADC! Otherwise the device will be damaged.
Greetings,
Stefan
dyanova
dyanovaAuthor
Hello Everyone,
I'm willing to use my uPSD chip to check li-on battery voltage. The uPSD suppose to alarm when the li-on battery voltage drops under 3.3V.
The uPSD manual claims that A/D input voltage should be less or equal to 3.6V.
In case I will connect the A/D to voltage between 4.1V and 3.6V, how it will behave? Will I receive dummy data? No data at all? Can this operation harm the device?
Thanks for help.
