happykkw
Feb 25, 2005 6:08 AM UTC
PSD Obj file.
Posted on February 25, 2005 at 07:08
PSD Obj file.
happykkw
happykkwAuthor
May 17, 2011 10:05 AM UTC
Posted on May 17, 2011 at 12:05
Hi all,
I got only a obj file(HEX format), and JCF file with uPSD 3233B. Can I get any PSD information from this Obj file? , such as ''Define PSD and MCU/DSP'', ''Pin/Node Functions'' ''Additional PSD Settings'' which defined in PSDExpress .
Thank you very much.
happykkw
happykkwAuthor
Thank you for reply!
Because I want to change the source and setting the PSD again, so I need to refer orgin PSD setting information. Do you have any suggestion to get the information from obj file, or other method?
I am just a PSD beginner, need help.
happykkw
happykkwAuthor
May 17, 2011 10:06 AM UTC
Posted on May 17, 2011 at 12:06
I mean that I don't have the ''ini'' which has original setting of PSD ,so I can not merge anything with HEX file, that is why I want to get that setting information from Obj file. I only have obj file, nothing else.
