hg-chen
programming socket board for STR711FR2H6 available?
Posted on November 24, 2006 at 10:53
hg-chen
hg-chenAuthor
Posted on November 15, 2006 at 23:02
Is the programming socket board for STR711FR2H6(BGA 64) available?
hg-chen
hg-chenAuthor
Posted on November 21, 2006 at 00:18
or if I want to make a programming socket board myself,
is the AN1775, STR71X HARDWARE DEVELOPMENT GETTING STARTED ,
the file I should refer to for H/W pin connection?
jgoril
Posted on November 21, 2006 at 07:45
I can offer you the following one:
DIL48/LFBGA64 ZIF STR71x, consists of 2 pieces:
BGA-TOP-84, ord. no. 70-0532 (more info at
http://www.elnec.com/sockcon_info.php?id=BGA-Top-84_ZIF
) and
BGA-BOTTOM-46, ord. no. 70-0531 (more info at
http://www.elnec.com/sockcon_info.php?id=BGA-Bottom-46
Certainly, it works only with our universal device programmers that support STR71x devices (Beeprog, BeeHive).
kaouther
The STR71x Hardware getting started A.N describes the minimum hardware resources required to develop an STR71x application independently of any package type.
Please have a look into the STR71x datasheet and you will find the STR711 BGA Ball Connections.
