shermantec
Jun 7, 2005 10:08 AM UTC
Programming - Pl's help and try to support
Posted on June 07, 2005 at 12:08
shermantec
Jun 1, 2005 9:40 AM UTC
Posted on June 01, 2005 at 11:40
Hello
with SoftecMicro Gang Progarmmer MP8011A and now i understand that it always erase default by manafacturer RC calibration values and i need to re-calibrate them BUT when i am using the ICP Indart one by one everything is working fine .
Pl's advice if you know about other vendor of Gang programmer that can solve my problem .
Amir Sherman
alain2399
Hi Amir,
As InDart is preventing the erase of the calibration option byte there isno reason why DataBlaze could not do the same.
You should ask Softec support to help you resolve your problem:
support@softecmicro.com
Best regards,
Alain
