huaer2000
May 18, 2005 6:36 AM UTC
programmer problem
Posted on May 18, 2005 at 08:36
programmer problem
huaer2000
huaer2000Author
May 9, 2005 10:51 AM UTC
Posted on May 09, 2005 at 12:51
dear sjo,
I have made flashbash and successful to program st72c334n4.
now i use it to program st7flite09 and found some problem. programmer serial port test is ok, I can write optionbyte, but I
can not write the flash erea. an error message is displayed
''operation Failed'' , coudl you help me solve this problem.
best regards,
venkateswara
If option bytes are being programmed successfully, it indicates successful communication and proper Flash function/ICC. But, did you check the Flash memory mapping in the 334 you are using and the Lite09?
