pitbag
probrlem with strap resistors
  • June 10, 2003
  • 862 views
Posted on June 10, 2003 at 17:35
pitbag
pitbagAuthor
Posted on June 10, 2003 at 12:59
When I use strap resistors with value 470K, system strap cannot work. Change value to 2K, it works fine. Any value greater than 2K will not work.
When strap DACKEN0-DACKEN2, I use 1K resistors.Any value greater than 1K will not work.
Use devices:
Main chipset: STPC ATLAS
SDRAM memory type: HY57V641620HG T-H
DACKEN0-DACKEN2 decode by 74HCT138
Is there any problem with my board?
moedeker2
I have a similary problem too. Please have a look here ''http://www.stmcu.com/forums-cat-431-6.html''
Sometime the problem is still there. So I will check if a value of 1K will solve my problem too.
Benno
