tech7
problems to install STVPTD on XP machine
  • May 25, 2004
  • 6 replies
  • 1259 views
Posted on May 25, 2004 at 11:57
tech7
tech7Author
Posted on April 07, 2004 at 12:26
I have just installed visual debug ver. 2.5.4 but when i start the debug it does not work and display this error message: connection error (LPT1) : gdi-error in dvp: communicator error
can you help me??
thank you
ldefend1
Posted on April 08, 2004 at 06:56
Hi Lino,
Which debugger are you using?
tech7
tech7Author
Posted on April 08, 2004 at 09:18
hi friul,
i use STVD7 development kit and the board is ST7MDT1/MDT5-DVP2 kit board.
OS is HP professional ver. 2002 SP1
tech7
tech7Author
Posted on April 08, 2004 at 09:19
hi friul,
OS is XP professional ver. 2002 SP1
md1
Posted on May 06, 2004 at 20:43
Hi lino,
Are you using this on a laptop?
What parallel port mode is set in your BIOS?
tech7
tech7Author
HI MD,
thanks in advance for your reply, i changed the parallel port set but the wrong go on.
I resolved my problem in this bad way: i format hard _disK and re-install windows XP and then STVD7. I don't known what is the difference but now the system work!!
