rcartarius9
Jan 13, 2008 3:45 PM UTC
Problems loading the monitor with the ST10Flasher tool
Posted on January 13, 2008 at 16:45
rcartarius9
Dec 5, 2007 9:24 AM UTC
Posted on December 05, 2007 at 10:24
I have problems with the ST10Flasher tool. This tool seems not to work on all machines. I use an own hardware (with ST10F269) and I have some PCs which are not able to flash a new hex-file.
I allways get the message that it is not possible to load the monitor.
On other PCs I have no problems.
On some PCs it takes up to ten times until I succeed.
I want to know on what it depends on if the ST10Flasher works.
najoua
Jan 10, 2008 11:41 AM UTC
Posted on January 10, 2008 at 12:41
Could you please tell me which version of the ST10Flasher you are using and on which platform you are running it (2000, XP etc...)?
Best regards,
Najoua.
newsamo
I have samo trouble....i read an hex file...and then when i try to rewrite it i get a file error...
