Yusuf Korkmaz
Jan 9, 2018 7:25 AM UTC
Problems in setting the duty cycle and frequency
Posted on January 09, 2018 at 08:25
Hello community,
i got a problem when i want to create on my stm8 eval board a pwm signal with 350khz and variable duty cycle from 0-100.
i calculate the the values for the registers as follows:
PWM Frequency = Clock of the Timer without Prescaler (16Mhz) / ARR +1 --> i choosed for arr 44 so i get apprx. 355kHz
But know i can not achieve the desired pwm resolution of 100, now i have 45 steps instead of 100.
Did you guys know how to solve this problem?
Thanks a lot
