wileti
Sep 24, 2007 9:35 AM UTC
problem with struct
Posted on September 24, 2007 at 11:35
problem with struct
wileti
wiletiAuthor
Sep 17, 2007 6:30 PM UTC
Posted on September 17, 2007 at 20:30
Hi folks!
I´m struggling with a weird problem: there is a struct in my code like this:
extern struct {
int Flags : 3;
int Write : 2;
int Read : 3;
}TestData;
Afterwards compilation, I got this error:
#error clnk Debug\sugar_project.lkf:1 symbol _TestData not defined (Debug\bk.o Debug\hid.o Debug\main.o Debug\my_appli.o )
I don´t know why the compiler prompts this message. I´ve tried to declare this same struct outside (in a .c file, because it is an external struct), but in this case the message is:
#error cpst7 user_var.c:122(2+8) redeclared external TestData
Is my extern declaration correct?
This problem is getting me headache...
I´ll be very grateful for hints...
Wilson
luca239955_st
Sep 20, 2007 5:28 AM UTC
Posted on September 20, 2007 at 07:28
did you solve this? Looks like you never actually declared the structure itself...
wileti
wiletiAuthor
Yeah, I´ve already solved it.
What I did, in summary, was declare my struct in User_var.h like this:
struct _TestData{
unsigned char Flags : 3;
unsigned char Write : 2;
unsigned char Read : 3;
extern struct _TestData TestData;
In User_var.c it was declared suitable like this:
After doing this, the error vanished!
Thanks a lot
Wilson
