peppecaselli
Oct 27, 2004 9:41 AM UTC
Problem with ST9 HDS2v2 with PC
Posted on October 27, 2004 at 11:41
alain2399
May 17, 2011 9:36 AM UTC
Posted on May 17, 2011 at 11:36
Hich version of the toolset are you using ? (see the about window).
peppecaselli
I have a problem, feature ‘s devices are:
1) ST9 HDS2V2 EMULATOR
2) ST92F120EMU presented on the board
Emulator and Computer are linked by parallel port LPT1
In the PC there is like O.S. Windows 2000 Service Pack 4.
Effected operations:
I start the emulator and it come is a state of: (lighting of LED) POWER, EMULATOR RESET, ST9 RESET
I start the program WGDB9 DEBBUGER and the emulator come in a state of RUN of course only the LED remaines alight showing the POWER.
The PC answeres with the following window:
ST9+ Debbuger : ->>ST9+ can't enter monitor mode
->> Reset the emulator!
I press OK
The program is opened with another window whose title is WARNING having the same message as before
Please help me!!!
peppecaselli
hi, the software is ST visual make version 2.1, GCC9 C compiler.
