amoreno
problem with SPRINTF()
  • June 9, 2009
  • 4 replies
  • 1094 views
Posted on June 09, 2009 at 23:19
amoreno
amorenoAuthor
Posted on February 09, 2009 at 12:51
Sirs, I need you help.
For long time I’m having randomize problems with my STR711 and IAR EWARM 4.41. They are related to SPRINTF().
Usually it worsk fine but when I modify some part of code, then another part code containing a SPRINTF() fails.
Does anybody had or have problems with this function?
Any advice?
I'm thinking to do my own source code for this function :(
Really desperate issue.
ALFA.
[ This message was edited by: amoreno on 09-02-2009 18:03 ]
kleshov
Posted on February 10, 2009 at 09:07
This could be caused by stack overflow.
paolo239955_stm1
Posted on April 09, 2009 at 12:18
Hi, did you solve the sprintf problem ? I am having same problem with ARM9, an I don't think is a stack overflow problem
Regards,
paolo
info37
Did you solve the problem with sprintf ?
I'm having an odd result using the %f to convert a float value. But it works fine with decimal values:
sprintf(buffer,''Number: %d'',anInteger); <--- Works fine.
sprintf(buffer,''Decimal: %f'',aFloat); <--- a 0.0 is returned
Mark
