info44
Mar 19, 2003 11:14 AM UTC
problem with 36 Mhz cristal
Posted on March 19, 2003 at 12:14
info44
info44Author
May 17, 2011 9:53 AM UTC
Posted on May 17, 2011 at 11:53
I've drawn a card around the upsd3434a at 36 Mhz. I try first with a 12Mhz cristal with 2 capacitor (10pF) and it works well. It works well also with a 24Mhz cristal. But with a 36 Mhz there is no oscillation (I use also 10pF capacitors) ? Does I need to use a cristal resonator like on the DK3200 kit ?
Thanks,
Sebastien
info44
info44Author
In fact there is an another problem with high speed quartz : current 36 Mhz cristal use the third overtone so it result a oscillation rate at one-third the desired speed so 12 Mhz. It's necessary to use a 36 Mhz cristal in is fundamental mode.
info44
info44Author
I've find the problem, I've got a complete bottle of 36mhz cristal who doesn't work.
yu-jun
Which voltage do you use?
