macke_a
Nov 9, 2006 9:19 AM UTC
Problem to write/read Flash
Posted on November 09, 2006 at 10:19
macke_a
macke_aAuthor
Oct 31, 2006 7:11 AM UTC
Posted on October 31, 2006 at 08:11
Hi !
I want to write to the flash with the following source code.
But after this, my programm is crash and I dont know how is the mistake?!
u32 TargetAdd = 0x400C2500;
u32 DataWrite = 0x0000222F;
u32 Read_Data = 0x00000000;
FLASH_Init();
FLASH_WritePrConfig(FLASH_B1F0, DISABLE);
FLASH_SectorErase(FLASH_B1F0);
FLASH_WordWrite(TargetAdd , DataWrite );
Read_Data=FLASH_WordRead(TargetAdd);
printf(''%x\n'',Read_Data);
FLASH_WaitForLastTask();
//FLASH_WritePrConfig (FLASH_B1F0,ENABLE);
I have read the other threads, but they couldn´t help me further.
I use the Keil µVision3 Compiler
Thank you in advance for help !
yvonperr
Oct 31, 2006 8:41 AM UTC
Posted on October 31, 2006 at 09:41
Hi
Use address 0x000C2500 not 0x400C2500. The library automaticaly adds the 0x400000000 to the Flash address.
Also address C2XXX is in Bank B1F1 not Bank B1F0.
Hopes this helps
[ This message was edited by: Yvon on 31-10-2006 14:14 ]
macke_a
macke_aAuthor
Oct 31, 2006 9:07 AM UTC
Posted on October 31, 2006 at 10:07
Thank you for answer!
I have tried the Flash Bank at B1F0 an the Target Address at 0x000C1000,
but nothing changes! Any other concept ?
macke_a
macke_aAuthor
Nov 2, 2006 6:25 AM UTC
Posted on November 02, 2006 at 07:25
Hey.. could nobody help me, about my problem ?
I find no information, so what take me further...
heribert
i write and read my flag from flash.
char *flag = ''0000'';
#define DownloadFlag 0x400C3FFC /* adress */
flag = (char*) DownloadFlag; /* read */
EIC_IRQConfig(DISABLE); /* Disable IRQ interrupts on EIC */
FLASH_SectorErase(0x00020000); //(FLASH_B1F1); Bank1 Sector 1
FLASH_WordWrite (DownloadFlag, *(unsigned int *) FlashBuffer); /*write*/
EIC_IRQConfig(ENABLE); /* Enable IRQ interrupts on EIC */
i hope it will help. Greetings Heribert
Also a Good example is the code from IAP download in the froum
