babidesai123
Mar 30, 2004 3:39 PM UTC
problem in programming through JTAG
Posted on March 30, 2004 at 17:39
babidesai123
May 17, 2011 9:59 AM UTC
Posted on May 17, 2011 at 11:59
hello,
I am using the uPSD323X from last one year. But for the first time i could see that the chip already programmed through JTAG ( more that 5 times)is not getting reprogram/erase.
It's not able to communicate through JTAG . but the previous loaded image is working fine
IT SHOWS: MISMATCH OF IDCODE
here is the attached log file generated
PLZ help
Purvi
jdaniel
Purvi,
I've seen this message if I accidentally have the wrong uPSD product selected in the JTAG programming screen within PSDExpress. For instance, if I was trying to program a uPSD3254A and I had selected the PSD854 as the device in the JTAG operation dialog box, it will show this error. Maybe take a look at this dialog (or your .jcf file if you're using it from the command line) and make sure it matches.
Best Regards,
Phaze426
babidesai123
hello,
i have not changed the user code from the default FFFFFFFF value.
regards
purvi
