jps
Sep 27, 2007 2:25 PM UTC
Problem going from ST7LITE05 to ST7LITE15B
Posted on September 27, 2007 at 16:25
jps
jpsAuthor
Sep 26, 2007 12:19 PM UTC
Posted on September 26, 2007 at 14:19
I usually use the ST7LITE05 and develop my program in assembly with SOFTEC indart STX and STVD7.
I'm trying to translate a old program from ST7LITE05 to ST7LITE15B and I have some problems to build my project. I get a build error and the map file seems to stay empty!
I have attached the ST7LITE15B include files and everything looks good?
Any idea on what happens and on how to solve it?
Thank you for your help.
jps
jpsAuthor
Thank you SCo,
You can find added the error file I get.
When I say ''attached files'' I mean that I have put the .include and .asm file for the ST7LITE15B in my project folder!
The build process seems to be OK. The problem is that the .lst and .map file are not generated? (the .map file stay empty).
Do you have a project working with a ST7LITE1xx controler running? In that case, could you send me the folder of this project (erase all you dont want to transmit in your .asm file). So I could start from this folder and no more from a ST7LITE05 project!
Whitebull
________________
Attachments :
cbe.err : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Cn&d=%2Fa%2F0X0000000bVJ%2FcpUNXwy3ndDwf20BRmC5rMnx5VaFmftx3pgCZKa6XO4&asPdf=false
