jorge2399
Jul 6, 2006 4:51 AM UTC
Problem building kernel of uclinux
Posted on July 06, 2006 at 06:51
jorge2399
jorge2399Author
Jul 5, 2006 4:13 AM UTC
Posted on July 05, 2006 at 06:13
Hi all,
I encoutered problem building kernel of uclinux.
After having set arm str7 toolchain, and done the ''make menuconfig'' as described in the ST application note,
I have a generated error during the ''make lib_only'' :
ucfront-gcc : command unknown
cc1.o Erreur 127
[alkl]erreur 2
I searched on the web , unsuccesfull !!
Thanx for your helps,
Rgds,
ps: i turn on red hat (kernel 2.6.9-5)
[ This message was edited by: jorge50 on 05-07-2006 09:51 ]
jorge2399
jorge2399Author
I found a solution :
do a ''make ucfront'' before the ''make lib_only''.
it seems to fix it!
Rgds
