li-fan
printf function in ST Visual Develop
Posted on December 08, 2005 at 06:29
li-fan
li-fanAuthor
Posted on December 07, 2005 at 00:07
Hi All:
In ST Visual Develop, the compiler is Cosmic, I use Win2K.
I use printf function, but there is no any out put in the Output winodws and DOS prompt windows . Where does the message out put?
Many Thanks
Li Fan
henrik239955
Posted on December 07, 2005 at 12:01
The library function does not put it out at all...
You have to write your own putchar like this:
char putchar (char c)
/* here you put c where you want... (UART/SPI/LCD) */
return (c);
luca239955_st
What Bood writes is correct (there is an old thread where all the details about how to rediret printf are explained), but I suspect it will not solve the OP problem; how the printf output is captured by the debugger / simulator is a question related to the debugger itself, in this case STVD7.
Hope it helps.
Luca (Cosmic)
