anilwpatil
Jan 23, 2009 4:15 AM UTC
Prefetch exception after interrupt remapping
Posted on January 23, 2009 at 05:15
anilwpatil
Dec 18, 2008 10:59 AM UTC
Posted on December 18, 2008 at 11:59
Hi All,
i am using str73x processor for my development. I am developing bootlaoder for my processor. i have application program which needs to download into processor via bootloader. I remap my interrupt in application code and whenever i enable the interrupt, my code loops into prefetch execption loop (code works fine without interrupt enabling)
i traced out the code by debugger whenever interrupt comes IRQ handler gets called and it then check for the interrupt source and then loop in prefetch execption.
i my code memory loacted at 0x80020000 (by default it is 0x80000000 where my bootloader code resides) interrupt is remapped to the RAM
Can someone help me analyse this problem.
anilwpatil
Thanks for your valuable time you spent on this query. I solved the problem and now my system is working :)
