tomas2
Feb 8, 2007 11:55 PM UTC
Please recommend a ST7 programmer
Posted on February 09, 2007 at 00:55
tomas2
tomas2Author
Apr 5, 2006 9:33 AM UTC
Posted on April 05, 2006 at 11:33
Hi all !
I have now used ST7 Flash Stick programmer/HE10 ICC interface for a while.
For field services etc - kindly recommend a smart and easy to use programmer ( Segger ? ).
A couple of them will also be sent to our distributors/service stations for fast and easy upgrades of products at spot.
New software from us via for eg. email.
Thanks in advance.
BR
Tomas
[ This message was edited by: tomasf on 05-04-2006 15:06 ]
info45
Apr 9, 2006 9:35 AM UTC
Posted on April 09, 2006 at 11:35
Hy tomasf,
I use Stick and I very satisfied.
If you wish use other programmer ( USB connection based), I have used InDart also.
Please see in www.softecmicro.com
By
kalun218
Apr 10, 2006 12:02 AM UTC
Posted on April 10, 2006 at 02:02
You can find more information about SofTec products as below webpage:
http://mcu.st.com/mcu/modules.php?name=Content&pa=showpage&pid=21
Or
http://www.softecmicro.com/
Of course, the best way is to contact SofTec technical support directly:
support@softecmicro.com
luter
Apr 10, 2006 2:39 AM UTC
Posted on April 10, 2006 at 04:39
Hi.
What do u need excatly: debugger/programmer for development or programmer for production?
tomas2
tomas2Author
Apr 18, 2006 8:54 AM UTC
Posted on April 18, 2006 at 10:54
Hi Luter,
I need a programmer for production and field service as described:
BR
Tomas
vincentchoplin9
Apr 18, 2006 10:52 AM UTC
Posted on April 18, 2006 at 12:52
RLink is a low-cost programmer/debugger supporting ST7. It is powered through USB (no need for an external power supply) and is provided with a programmation executable that makes it very easy to use for field services.
Have a look at these links for more information:
http://www.raisonance.com/products/RLINK.php
http://www.st.com/stonline/products/literature/bd/11967/stx-rlink.htm
Vincent
luter
Apr 19, 2006 3:52 AM UTC
Posted on April 19, 2006 at 05:52
For production i know only 3 gang programmers:
1) SofTec MP8011
http://www.softecmicro.com/products.html?type=detail&title=MP8011A
2) Elnec JetProg
http://www.elnec.sk/jetprog.php
http://www.elnec.sk/jetprog_multi.php
3) BP2610x2 Concurrent Programmer 2-site
BP2710x2 Concurrent Programmer 2-site
BP2710Mx2 Concurrent Programmer 2-site
http://www.bpmicro.com/web/bphome.nsf/unids/82B312E4E44B057886256FC80081C2E6?opendocument&Cat=multi
softec_asia
SofTec has released a new professional grade ICP programmer,
http://URL=http://www.softecmicro.com/products.html?type=detail&title=FlashRunner
. It is a universal and gangable ISP based programmer. Moreover, it could work in standalone mode or host-based controlled via ethernet, RS-232 or USB. The ISP programmer is especially designed for easy ATE integration for saving production time and cost.
I suggest you to check more details from
[ This message was edited by: mcu_newbie on 09-02-2007 05:27 ]
