ibrahim c.p
Oct 1, 2017 10:08 PM UTC
Please help
Posted on October 02, 2017 at 00:08
 I have a mother board of audio, video and gps with STM8S207K6 MCU that is working condition. When I try to read eeprom from the device, the message will appear 'Can not communicate with the device.
Check the swim cable connection and check all the needed pin connection or the swim connecter
If the application code uses swim desable and reset pin as out put or has desabled swim clock driver
Try now to switch off and on the application power while nrst pin forced low'
All pins are connected with same as mentioned .
Pins of Swim, Nrst, VDD and GND.
    Oct 2, 2017 2:06 PM UTC
    Posted on October 02, 2017 at 16:06
    Sorry what's the question here?
    Is this a device, board or software you designed, or worked on, or someone elses?
    Oct 2, 2017 9:18 PM UTC
    Posted on October 02, 2017 at 23:18
    A device with read-out protection would preclude you from accessing or debugging.
