info80
Aug 19, 2005 9:30 AM UTC
Periodic Timer Interrupt Function
Posted on August 19, 2005 at 11:30
info80
info80Author
Aug 18, 2005 12:23 PM UTC
Posted on August 18, 2005 at 14:23
I'm using STR710.
I would like to create an exact 1ms periodic interrupt routine.
I have not found yet, how to modify the counter-register.
info80
info80Author
Thank you very much for the good example, it works and I understand it now.
Is it right, that the timer0-function does not need any output-pins? in your example the Pin P0.1 is only to show the time, isn't it?
Thanks, by
