zsu
Dec 9, 2009 8:48 AM UTC
Period of IWDG issue.
Posted on December 09, 2009 at 09:48
    baroudi
    May 17, 2011 1:04 PM UTC
    Posted on May 17, 2011 at 15:04
    Hi zsu,
    I think you should add
    IWDG_KR = 0x55 ; start the IWDG
    after
    IWDG_RLR= 0xff ; // Time-out period at about 63.7ms.
    I think IWDG_KR = 0x55 ;doesn't start the IWDG but It enables access to
    RLR and PR registers.
    Let me know if you have some news.
    With regards,
    zsu
    zsuAuthor
    Solved. There is a trick.
    If you use instruction in order as below, it doesn't work.
    IWDG_KR = 0x55 ; // Enable access to IWDG_PR and IWDG_RLR
    IWDG_PR = 0x02 ; // divide by 16.
    IWDG_KR = 0xcc ; // Start IWDG.
    To make it work, you have to put instructions in order as below.
    :p
    zsu
    zsuAuthor
    Default period of IWDG is about 15.90 ms. I try to change it to 63.70 ms by using instruction below. But it does not work. Its period keeps at 15.90 ms.
    Any trick ? Your help will be appreciated.
    During debugging, IWDG_PR keeps zero (default value).
