udo1
Jul 8, 2008 8:40 AM UTC
openOCD security bit
Posted on July 08, 2008 at 10:40
sjo
May 17, 2011 7:54 AM UTC
Posted on May 17, 2011 at 09:54
the security bit is the using the str9xpec driver
so in your config you need the str9xpec driver:
flash bank str9x 0x00000000 0x00080000 0 0 0
flash bank str9x 0x00080000 0x00008000 0 0 0
flash bank str9xpec 0x00000000 0x00080000 0 0 0
# assert reset (srst)
#jtag_reset 0 1
then to lock the device
# enable turbo mode
str9xpec enable_turbo 2
# lock str9
str9xpec lock 2
# disable turbo
str9xpec disable_turbo 2
# let device run - resetting tap aswell
jtag_reset 1 1
jtag_reset 0 0
see the following for more info:
http://forum.sparkfun.com/viewtopic.php?t=9451
Cheers
sjo
[ This message was edited by: sjo on 08-07-2008 14:11 ]
udo1
udo1Author
I'm trying to set the security-bit on a STR912FAW44. I found a PDF (http://www.st.com/stonline/products/literature/pm/11659.pdf) that describes which register needs to be set but I have no idea how to do this using openOCD. I use a wiggler-compliant jtag device to program the processor.
