shermantec
Aug 26, 2003 1:37 PM UTC
Op Amplifier
Posted on August 26, 2003 at 15:37
Op Amplifier
shermantec
Jul 31, 2003 6:41 AM UTC
Posted on July 31, 2003 at 08:41
Hello
I want to use the Op-Amp as an Interrupt . I need halt the cpu and initiate a run mode on a predefined analog input threshold .
Is this feature possible with the ST7Flite0x family ?
Latino from Israel
itsmejatinus
Aug 14, 2003 12:11 PM UTC
Posted on August 14, 2003 at 14:11
The problem is not very clear to me. Could you please explain the requirement in detail ?
[ This message was edited by: Ranjeet on 18-08-2003 13:03 ]
sjo
Aug 15, 2003 10:42 AM UTC
Posted on August 15, 2003 at 12:42
I'm afraid this is not possible with the flite or any ST7.
The only devices with this sort of functionality are the 321/521 which feature an EVD pin as part of the Auxiliary Voltage detector(AVD), but this is a fixed threshold relative to the LVD settings intended for monitoring voltage rails.
Hope this helps
SJO
sisto
You may use an ei0 external interrupt port I/O pin connected to the digital output of a voltage comparator (instead of an operational amplifier) with an appropriate filtering and histeresis theresolds to avoid an unpredictable enter-exit from HALT mode due source voltage ripple .
For example use fall sense interrupt to enter in halt mode by HALT instruction and rise sense to exit from HALT mode.
That means: the interrupt handler routine should change the rise/fall sense of ext irq and handle a flag to monitor this toggle situation.
The flag may be avoided using the same or another input to read the digital level of voltage comparator output.
Is better to use a micropower RailToRail Comparator.
Sixtus
