jm_it
Dec 23, 2005 11:44 AM UTC
_nop_()
Posted on December 23, 2005 at 12:44
_nop_()
jm_it
jm_itAuthor
Dec 20, 2005 12:02 PM UTC
Posted on December 20, 2005 at 13:02
I have just taken a project already started on the ST10F168. My problem is to understand when I am obliged to use the _nop_() function. Because in my project, it's using in abundance...Is it really necessary ??
When you set a port or a state(input/output), do you put a _nop_() (or 2) after ??
In general, when the use of this function is necessary ??
Thanks in advance
JM
jm_it
jm_itAuthor
Dec 21, 2005 9:27 AM UTC
Posted on December 21, 2005 at 10:27
So, NOP are necessary just after changing the state of one port pin direction of a port, or also after changing the value of the port pin ?
which NOP are necessary in the example below. Just 1 (or 2) after changing the direction, or all ?
Code:
P8=0xFF;
_nop_();_nop_();
DP8=0xFF;
_nop_();_nop_();
JM
jm_it
jm_itAuthor
Thanks again !!!!
