wolver
Apr 22, 2009 2:06 AM UTC
need help--STM8A bootload
Posted on April 22, 2009 at 04:06
    wolver
    wolverAuthor
    May 17, 2011 1:02 PM UTC
    Posted on May 17, 2011 at 15:02
    hello:
    Is there anyone ccould give me some example of STM8A bootload source code?
    My boss hope me make MCU code can be updated from CPU I2C...
    best regards!
    wolver
    2009-4-21
    [ This message was edited by: wolver on 21-04-2009 07:09 ]
    mozra27
    Hi Wolver,
    You can refer to this document:
    AN2659: ''STM8S in-application programming (IAP)using a customized bootloader'' it can help you :D
    http://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&FAM=113
    mozra
    wolver
    wolverAuthor
    Hi mozra
    Yes, I have seen that pdf, But I still can not find right way to home...
    Any other document?
    thanks a lot!
    wolver
    mozra27
    Hi Wolver,
    You can refer to this application note:
    AN2737: ''Basic in-application programming example using the STM8 I2C and SPI peripherals'' available on the following link:
    http://www.st.com/stonline/products/literature/anp/14584.pdf
    mozra
    wolver
    wolverAuthor
    Hi mozra
    Great thanks! You are a enthusiastical man.
    I think I can try to go home now...
    By the way, This forumsit login from China is too slowly...
    best regards
    wolver
    [ This message was edited by: wolver on 22-04-2009 07:45 ]
