leoren_tm
Sep 1, 2010 8:52 AM UTC
Need Help on 1526-eval USART.
Posted on September 01, 2010 at 10:52
    leoren_tm
    leoren_tmAuthor
    May 17, 2011 1:10 PM UTC
    Posted on May 17, 2011 at 15:10
    Thank you on that....but how can i use PA as USART, cause it uses PC, no port remaping option but it was indicated at datasheet that it can be use...
    lowpowermcu
    Hi leo,
    In STM8l15x_StdPeriph_Lib you can find a set of examples (USART, ADC, Timer...):
    Download it from:
    http://www.st.com/mcu/familiesdocs-120.html#Firmware
    MCU Lüfter
    lowpowermcu
    Hi leo,
    You find in the product reference manual of stm8l15x, go to system configuration section.
    link for download: http://www.st.com/stonline/products/literature/ds/15226.pdf
    If you are usign the firmware provided by ST, you can use SYSCFG_REMAPPinConfig() function.
    link for download:
    http://www.st.com/stonline/products/support/micro/files/stm8l15x_stdperiph_lib.zip
    Good luck,
    MCU Lüfter
    leoren_tm
    leoren_tmAuthor
    Sorry was not that clear.
    i mean, its default port use was
    PC2/[USART1_RX](3)/LCD_SEG22/ADC1_IN6/COMP1_INP/VREF_OUT
    and
    PC3/[USART1_TX](3)/LCD_SEG23(2)/ADC1_IN5/COMP1_INP/COMP2_INM
    and in my application I want to use this as my USART
    PA2/OSC_IN/[USART1_TX](3)/[SPI1_MISO] (3)
    and
    PA3/OSC_OUT/[USART1_RX](3)/[SPI1_MOSI](
    lowpowermcu
    Could clarify the point !
    leoren_tm
    leoren_tmAuthor
    thank you :)
