SN.3
Need alternate for this EF6809P Micro processor.
I need alternate for the following component. Also I need End of Life of the alternate part is about 7 Years.
  1. EF6809P(Micro Processor)
I am looking forward your valuable reply.
Thanks.
Ozone
Principal
December 10, 2020
I'd say, forget about architectural compatibility. The 6809 is about 40 years old.
Port your application to a Cortex M device.
This would probably require rewriting, assuming no HLL was used.
Or consider a FPGA: https://opencores.org/projects/system09
SN.3
SN.3Author
So there is no direct alternatives for 6809 processor. But Cortex M devices are too advanced since all the related part for 6809 has to match with Cortex M. Also Cortex M devices are having more functionality that may not be required for this particular project.
Ozone
Principal
December 10, 2020
This forum is mostly user driven. And as such, mostly Cortex M users.
You can of course try to contact ST or a distributor directly, help finding a direct replacement.
And so what ?
You will want to map all existing functionality to a newer MCU, and not vice versa.
You will find cheap Cortex M0/M0+ devices with low pin count and a lean set of peripherals.
You get about one order of magnitude more performance for a similar price, more than enough to run a cleanly written and maintainable firmware.
In contrast to the assember code of the Z80/8052/6809 era.
Uwe Bonnes
Chief
December 10, 2020
Look for HDL code for the 6809 out there and implement it in an FPGA if you need cycle-by -cycle compatibility.
