NB-IoT board
I'm working on a project that requires the implementation of NB-IoT and to do this I started by testing the Discovery Kit B-L462CELL1, which is very poorly documented. I also noticed that the LBADXX1SC modem used by the kit is now obsolete.
Can you recommend a development board from ST Microelectronics that would enable me to do NB-IoT (with zephyr would be a plus)?
Thanks in advance.
Andrew Neil
Andrew NeilBest answer
Did you see my update - LBADXX1SC doesn't actually seem to be obsolete?
As I said any module or board should be usable - just find one which suits your requirements.
Andrew Neil
Does it really need to be a board from ST ?
Even with the B-L462CELL1, the NB-IoT module is 3rd-party (Murata).
Generally, such modules are controlled via AT commands - so, once you can do AT commands, you can use any module...
PS:
Not according to Murata's site?
celikaAuthor
Not necessarily a board from ST. If you have another module or board to advise me, I'm interested.
Andrew Neil
