mm3
Moving from old ST62T10 to new ST62T10C with LVD
  • July 1, 2004
  • 4 replies
  • 1132 views
Posted on July 01, 2004 at 12:25
mm3
mm3Author
Posted on March 11, 2004 at 13:36
Hi, I'm using ST62T10 with the same firmware program since -91 and have programmed >20000 pcs in my little ''ST62E1x Basic programmer'' since!
However now I would like to use the internal LVD instead of the Dallas reset IC I have used all years.
Is it possible to enable the option bit for this with my old programmer?
The software gives me no option for this but maybe possible anyway?
Is it ok to program the new C version in this programmer?
(I have done it for some years and it seems to work)
This is all old stuff and I would prefer not to change more than absolutely necessary.
Maybe I will be lazy and continue to use the Dalllas IC.
simonharrison9
March 12, 2004
Posted on March 12, 2004 at 08:21
Does your system operate a windows user interface, or through DOS?
If DOS, then you will need to purchase a new programmer.
I know customers who have tried to use the old kit with 'C silicon and had numerous problems.
Also, I think that you will find no software to support 'C parts on that programmer.
I would also be very surprised if you can still buy the old ST62T10 parts.
It would be worth changing over.
regards,
Simon
mm3
mm3Author
Posted on March 12, 2004 at 11:49
Ok, thanks Simon.
So I will buy a new programmer.
Mikael
avinr
Hi Simon/Mikael,
I am trying to obtain the dos software to download a hex file to the ''ST62E1x Basic programmer''.
Mikael, I noticed in your email that you have been using this programmer.
I am doing legacy support on some old code and currently have this ST programmer available.
I have been to the ST website and tried the ''ST Windows epromer'' but it does not have support for this programer.
I would really appreciate your help.
Kind regards
Avin
[ This message was edited by: Avin on 01-07-2004 15:59 ]
[ This message was edited by: Avin on 01-07-2004 16:01 ]
