Jun 12, 2026 7:43 PM UTC
Minimum operating temperature for BAT30 Schottky diode
The BAT30 datasheet shows a storage temperature of -65 to 150C and a maximum junction temperature of 150C.  There is no mention of the minimum operating temperature though.  Can you clarify?
Peter BENSCH
Peter BENSCHBest answer
Jun 12, 2026 8:51 PM UTC
Welcome ​@GeorgeK, to the community!
With Schottky diodes, the critical limits are generally on the hot side of the temperature scale, where destruction can occur. At low temperatures, some parameters do deteriorate, but there is no risk of destruction, so no value is given.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
GeorgeKAuthor
Jun 12, 2026 9:20 PM UTC
Okay, I see the forward voltage curves going down to -40C.  Our application will not go below this, but I’m setting this part up in our system.   I added your note.   Thanks!
