ulivo15
Aug 13, 2004 6:49 AM UTC
MIDI and ST7
Posted on August 13, 2004 at 08:49
MIDI and ST7
ulivo15
ulivo15Author
Jul 28, 2004 8:51 AM UTC
Posted on July 28, 2004 at 10:51
Hi to everybody,
i'd like to make a sipmle MIDI piano that should be connected to my computer. Which ST7 have implemented the MIDI serial protocol?
I thank you
jatin
Aug 10, 2004 4:48 AM UTC
Posted on August 10, 2004 at 06:48
ST7 do not have any protocol by the name MIDI serial protocol. But have I2C, SPI etc. Could you explore more about the MIDI serial protocol?
parveen
Aug 12, 2004 6:07 AM UTC
Posted on August 12, 2004 at 08:07
You can use ST7 micros with SCI - Serial communication Interface (e.g. devices like ST72F264 or ST72F521). The SCI can be interfaced to create MIDI interface and I/Os can be programmed as your Piano keys.
Hope this helps,
ParveenG
ulivo15
ulivo15Author
Hi ParveenG,
I have tried with the SPI protocol with a st7lite09, as you can find in my other question, but after a byte trasmission i have 5 volt fixed at pin 3 of the port B (used for the SPI trasmission in master mode). I should have 0 volt. I have tried in several ways, but i couldn't find the way to reset the pin 3 of the port B. Something is wrong? Have you a solution?
I thank you
