Memory usage, stm8
Hello
STM8S microcontroller. Cosmic compiler. How can I find out how much memory my C program is using and for what purposes?
    MykolaLevunBest answer
    I wrote to Cosmic technical support and they responded with the following: "It's described in the linker section of the compiler manual (CXSTM8_UsersGuide.pdf)."
    March 7, 2024
    If the Linker generates a .MAP file perhaps review that.
    Yes, the linker generates a .map file. It is not particularly clear what these segments mean (see Figure 1 below)?
    What do the numbers near the parentheses and in the parentheses mean? What do the arrows (>) next to some numbers mean (see Figure 2 bellow)?
    What do the arrows such (>) and such (-->) mean (see Figure 3 bellow)?
    Is there information on this topic somewhere? I did not find it in the Cosmic compiler documentation.
    Andrew Neil
    Did you try https://www.cosmicsoftware.com/support.php ?
    or https://www.cosmicsoftware.com/contact.php ?
    MykolaLevunAuthorBest answer
