Workalot
Dec 5, 2010 7:02 AM UTC
Meaning of Cosmic's segment .bss size overflow error
Posted on December 05, 2010 at 08:02
    Andrew Neil
    May 17, 2011 1:11 PM UTC
    Posted on May 17, 2011 at 15:11
    ''The page 9 reference (I had read it) escaped my understanding as to its ability to discern the Cosmic compiler.''
    It seems pretty clear to me - in what way would you have it changed?
    ''Perhaps a mention could be included in the manual?''
    Which manual do you mean?
    Since the Standard Peripheral Library supports both Cosmic & Raisonance compilers, its source code would seem like an obvious place to look to see how it distinguishes the two; eg, in stm8s.h:
    /*                   Library configuration section                            */
    /* Check the used compiler */
    #if defined(__CSMC__)
     #undef _RAISONANCE_
     #define _COSMIC_
     #define TINY @tiny
     #define NEAR @near
    #elif defined(__RCST7__)
     #undef _COSMIC_
     #define _RAISONANCE_
     #define TINY page0
     #define NEAR data
    #else
     #error ''Unsupported Compiler!''          /* Compiler defines not found */
    #endif
    Workalot
    WorkalotAuthor
    Thank you, and succinct.
    The page 9 reference (I had read it) escaped my understanding as to its ability to discern the Cosmic compiler.  Perhaps a mention could be included in the manual?
    luca239955_stm1_st
    1744 is the size of the overflow, that is, the difference between the actual size of the segment and its maximum size (as specified by the -m parameter for that segment, in the linker file)
    As for your other question, I quote the user manual, page 9:
    The COSMIC compiler defines the __CSMC__ preprocessor symbol....
    Regards,
    Luca
    PS: note that when you have a linker error the map file is NOT created.
